Davejp
Dec 10, 2021Tutor
Microsoft Teams dropping continuously
We are using an XR1000 gaming router and when I use Teams I continuosly drop. This is during the day when we have very little traffic on our home system as kids are in school. Is there a setting that...
Davejp
Dec 10, 2021Tutor
What are the security implications/risks of setting to open? And would would any security concerns be migitated by the fact that I'm running McAfee?
Netduma-Fraser
Dec 10, 2021NetDuma Partner
It's quite safe, the firewall is slightly relaxed but it will not cause you any issues - I run it on my own connection without issue
- DavejpDec 10, 2021Tutor
Thanks.
Should I also Disable SIP ALG and Disable Port Scan and DoS Protection?
I've read where these can also be causing some of the issues.
- Netduma-FraserDec 10, 2021NetDuma PartnerYes you can toggle those options as well if it's still not working and it could help
Doesn't seem to help. My wife was just on a Teams meeting and it kept losing connectivity. I ran a ping test on the IP address being used by her work PC and see that the response is usually less than 5ms but about every 30 pings it jumps to over 400ms for 1 ping, then goes back down to around 4-5ms. Not sure if this is the problem? Any ideas?
