Cc0320
Apr 26, 2021Tutor
Mifi7000 and xr300
I need help I want to connect a MIFI7000-A529 which has the internet service to a xr300 nighthawk use xr300 for the ethernet connection is this possible?
Netduma-Fraser
Apr 27, 2021NetDuma Partner
Yes that should be possible, connect the XR300 WAN/Internet ports to one of the LAN ports on the MIFI and it should get a connection
- Cc0320Apr 27, 2021TutorThe mifi has a type-c connection for charging and a usb port for charging another device only the type-c port I think you can use for something other than charging the mifi
- Netduma-LiamApr 28, 2021NetDuma Partner
OK, I'd suggest confirming with MIFI that this port can be used for wired connections and in that case you may need to buy an adapter in order for it to be able to connect to the XR300s WAN port.
- Cc0320Apr 29, 2021TutorCan the MiFi and the nighthawk xr300 be connected wirelessly were the MiFi is giving the router a internet signal
