Kianmd
Mar 02, 2019Tutor
Modem/router setup
Hi I have set up my NETGEAR dm200 modem and set it to modem only mode and it is saying there is no internet connection. When I plug my xr500 into the LAN port it is still saying it is unable to connec...
Mar 03, 2019Guru - Experienced User
Power OFF both modem and XR router. Besure your using a good quality LAN cable between the modem and router. Power ON the modem and let it sync. Then power ON the XR router. Have a wired PC connected to the XR router and using a web browser, walk thru the setup wizard for the XR router.
Kianmd wrote:
Hi I have set up my NETGEAR dm200 modem and set it to modem only mode and it is saying there is no internet connection. When I plug my xr500 into the LAN port it is still saying it is unable to connect to the internet. Please any help would be appreciated
Kianmd
Mar 03, 2019Tutor
Hi, thanks for the help I will try this process again following as you have said and will get back to you on whether this works. When looking through the forums it seems other people have had the same problem as myself and they seemed to have no success in fixing it but I will try this.
- FURRYe38Mar 03, 2019Guru - Experienced User
I haven't had any issues with my XR router, however I use cable modem. The DM is a DSL modem.
Let us know how it goes...
