Fibtls18
Feb 24, 2018Guide
moderate Nat xr500
moderate nat with xr500 and cod ww2 ive done everthing from resetting router and network settings to wireless and wired connections can not get an open nat on ww2. Something is fishy as ww2 tells me ...
- Feb 24, 2018Hi Daniel, if you put the console IP from Device Manager into Settings > WAN Setup > DMZ you will definitely have an open NAT. Yes CoD can give incorrect readings. If you have a device selected on the Geo-Filter set it to Spectating Mode until you get onto the game and ready to search for a match. Then switch back to Filtering Mode for when you're about to search for a game.
Fibtls18
Feb 24, 2018Guide
also i have read the posts about false readings while booting up the console and geo filter enabled. could this be the case? if so how do i disable the geo filter while booting up? sorry for the questions i have only had the router 2 days and still getting used to it.
daniel
