Fibtls18
Feb 24, 2018Guide
moderate Nat xr500
moderate nat with xr500 and cod ww2 ive done everthing from resetting router and network settings to wireless and wired connections can not get an open nat on ww2. Something is fishy as ww2 tells me ...
- Feb 24, 2018Hi Daniel, if you put the console IP from Device Manager into Settings > WAN Setup > DMZ you will definitely have an open NAT. Yes CoD can give incorrect readings. If you have a device selected on the Geo-Filter set it to Spectating Mode until you get onto the game and ready to search for a match. Then switch back to Filtering Mode for when you're about to search for a game.
Fibtls18
Feb 24, 2018Guide
also i have read the posts about false readings while booting up the console and geo filter enabled. could this be the case? if so how do i disable the geo filter while booting up? sorry for the questions i have only had the router 2 days and still getting used to it.
daniel
Netduma-Fraser
Feb 24, 2018NetDuma Partner
- Fibtls18Feb 24, 2018Guide
That fixed the wireless console. thank you! now on to the wired, this one still says moderate even after clicking spectating mode. Any way to get around this moderate nat on a wired conection?
daniel
- Netduma-FraserFeb 24, 2018NetDuma PartnerAh you didn't mention two consoles! Are both consoles open in their Network Settings? If not the Xbox allows you to choose a port it uses so make sure it uses a different one than the other. If they're both open in their network settings than it is just a false reading on the game. It doesn't actually mean you have a moderate NAT.
both consoles are ps4. The boys in wireless has type 2 nat on console. He now has open on ww2 after putting it in DmZ. My playstation is wired right next to the router, my console also has type 2 nat, but moderate on ww2 even after clicking spectating mode on geo filter. i am also leaning towards a false reading but just want to be sure.
- Icebergblue55Feb 26, 2018AspirantSwitching over to spectating mode solved the issue with connecting with EA servers in the geo filter section
