profe's avatar
profe
Initiate
Sep 03, 2019
mom looking for gaming router - help please!
Hello!
I'd really appreciate some guidance. My son's PING is way too high for Fortnight on our Lenovo gaming desktop (all-in-one). I am hoping a new router will help solve the problem. He's interested in the XR500 router.
My question is: what do I do when I get it? Do I need to have more gear in order to make it work? I assume I need Ethernet cords. Would the same apply for XBox?
I'm pretty clueless, and I would love a little guidance!
Thank you!
profe
  • We'll need a bit more information:
    What ping is he getting?
    What is your approximate location (country)?
    Does the high ping happen all the time or at specific times such as peak or when people in the home are using the internet at once?
    You would follow the quick start guide and go through the setup wizard on the interface. We then have some optimal settings guides for how to set it up for gaming. You should be provided an ethernet cable to connect it to your existing modem/router but may need another to connect the Xbox to it which is better for ping than WiFi.
    • profe's avatar
      profe
      Initiate
      Hi! Thank you for your response!
      His ping ranges from 280-1100. He says it doesn't really matter who else in the house is connected to wifi.
      We are in Massachusetts, USA.
      Any more suggestions would be much appreciated!
      • Netduma_Alex's avatar
        Netduma_Alex
        NetDuma Partner
        A few more questions:
        Is your computer currently connected via ethernet or wifi? What broadband speed do you pay for?
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem the NG router is connected too? Built in wifi router here by chance?
    Gaming should be done over a LAN wired connection for best performances and operation.
    profe wrote:
    Hello!
    Thank you!
    profe
