zeth07
Oct 21, 2025Aspirant
Multiple games matchmaking "messes up"?
 I have noticed this issue in two separate games that I've played and while it could be just the games themselves the fact that both games have effectively the same problem happens makes me question i...
zeth07
I'd have to find a time where I can separately test that since other people need to use the internet throughout the day for stuff more important than me playing a game so that I would have to look into at a different time.
But I can share the actual examples of the problem happening so you can at least see what is going on.
EXAMPLE 1: This was 2 years ago, I was having other problems which could have lead to this but the fact that the same situation still happens means whatever was fixed previously wasn't a solution for this specific problem either.
https://youtu.be/fVFnRzK8Fa8?si=9HhOoCI-tv2ZDkEs
EXAMPLE 2: This was 7 months ago, in this example you can see that I DON'T have the connection filters set to a higher standard, meaning it should try to match me with ANYONE and yet it was messing up anyway.
https://youtu.be/eW1hAa3ZIis?si=Xgv2ZNVw3snpel9V
EXAMPLE 3: This was less than a month ago, in this example you can see the connecting looping on the left side of the screen, previously I had played different people for over 1 hour and then it starts acting like this. And this happens "regularly" each time I play this game, it is like it just stops working for no reason and feels similar to the above examples in an entirely different game.
https://youtu.be/OK-U1nfLjyk?si=CJR_npg3BktrhhYp
Netduma-Fraser
Oct 21, 2025NetDuma Partner
That's understandable, I think it's an important step to determine if it could be a router issue or an ISP/game issue
