zeth07
Oct 20, 2025Aspirant
Multiple games matchmaking "messes up"?
I have noticed this issue in two separate games that I've played and while it could be just the games themselves the fact that both games have effectively the same problem happens makes me question i...
Michael3456
Oct 25, 2025Aspirant
I’m seeing the same issue on PS5 with multiple P2P fighting games. After a few matches, the games enter a ‘Connecting’ or ‘Checking Opponents Connection’ loop indefinitely. My wired connection is stable, UPnP is on, and port forwarding is set, so it seems like a NAT/session handling problem rather than a connection issue. Has anyone found a reliable workaround for these matchmaking loops?
- Netduma-FraserOct 25, 2025NetDuma Partner
Do you have an Open NAT? In most cases you won't need port forwarding and if the rules have been done incorrectly then this could make it worse. In WAN Settings set NAT to Open and see if that helps at all.
