zeth07
Oct 20, 2025Aspirant
Multiple games matchmaking "messes up"?
I have noticed this issue in two separate games that I've played and while it could be just the games themselves the fact that both games have effectively the same problem happens makes me question i...
zeth07
Nov 02, 2025Aspirant
Can I get an official explanation for why the Geo-Filter is showing "peers" in random places like outside of Africa, one in Europe, and sometimes in South America?
That doesn't really make any sense and if it is just a random quirk in the router why hasn't it been fixed after all this time through an update?
Netduma-Fraser
Nov 04, 2025NetDuma Partner
IPs are bought and sold, one month it might belong to someone in Australia, the next month it could be in the US. IP databases will by the very nature not be 100% accurate. We have an IP database and just like all others it needs to be updated regularly, that being said, true peer IPs i.e. a person are more likely to be mislocated as we wouldn't necessarily have an accurate location for them. If you provide the IDs of those ones you've mentioned we can have a look at correcting them.
- zeth07Nov 04, 2025Aspirant
I will have to get the IDs later tonight when I test it again but this has been ongoing for quite a while and not just a month by month basis which makes me think it is a visual bug in the router or some other explanation needed which is why I ask and why I'm curious how it hasn't been "fixed" if it is a known reason.
The one "peer" is literally in the ocean the west of Africa which is NOT plausible for where I am located and what I am expected to be matched with even with the most unreasonable search parameters.
The other thing I notice is that usually one of the IPs are like 192.xxx.etc which makes me think it is a local IP thing and I question why that is even showing up like it does. The other one is like 10.xxx.etc which is a similar local IP but literally being picked up in Europe or whatever which I know isn't the real location. For example when I ping Google DNS 8.8.8.8 with PingPlotter I can see there are a few 10.xxx.etc IPs inbetween my ISPs IPs that I know are "private IPs" for whatever reason, and while I don't understand the purpose or what my ISP is doing with that I see a similar "peer" show up like that on the map in the random location with a similar IP.
So that's why I'm asking "why" the router is visually showing these things in the Geo-Filter the way they are shown and if they aren't accurate how come it isn't something fixed after such a long time.- Netduma-FraserNov 04, 2025NetDuma Partner
The peer off Africa is a visual bug but won't effect anything and the resources to resolve that are not worth the gain. If you get the ID for one of the 10 ones we can take a look
Ok I got some of the IDs tonight,
These were 10.0.0.xxx:
610aa16ca700fb00
610a743fa700fb00
And then these were 192.168.xxx.xxx:
c5c009d45d64a3a8
61c0c18c5d00a3a863c0420d5d02a3a8
