motherfer
May 23, 2023Aspirant
My cell phone takes 5-10 minutes to send simple pictures when the wifi is connected
My cell phone takes 5-10 minutes to send simple pictures when the wifi is connected. They happen almost instantaneously when not. I read some forums that stated that disbabled the Geo-Filter would fi...
michaelkenward
May 24, 2023Guru - Experienced User
motherfer wrote:
Please provide any assistance you can, or a piece of hardware that isn't a piece of junk.
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.
As to "the latest available Firmware," There are various ways of checking the firmware, some of them are not reliable. As we know from previous conversations here, the only way to confirm that is with the number.
