motherfer
May 23, 2023Aspirant
My cell phone takes 5-10 minutes to send simple pictures when the wifi is connected
My cell phone takes 5-10 minutes to send simple pictures when the wifi is connected. They happen almost instantaneously when not. I read some forums that stated that disbabled the Geo-Filter would fi...
Netduma-Fraser
May 25, 2023NetDuma Partner
The Geo-Filter causing it would only apply if you've added the phone to it, unless you're a mobile gamer there wouldn't be a need to do that. To get the feature loading though, go to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, wait 2 minutes before accessing and see if it works then please.
What are your QoS settings? That's most likely the cause for the slow uploads.
