rippajohn
Feb 14, 2022Tutor
My Nighthawk XR1000 keeps having no Internet one only one device
Hi there, I purchased this router around three months ago, and it has been a nightmare. When it works its great, but i always have problems with internet connection. I have three computers connecte...
Netduma-Liam
Feb 15, 2022NetDuma Partner
Could you perhaps try reserving an IP address for each device that's been problematic from the LAN settings? See if that helps with your issue.
rippajohn
Feb 16, 2022Tutor
Yes, that seems to work for the computer. Thnaks
Any Idea why the guest networks dont have internet?
- Netduma-LiamFeb 17, 2022NetDuma Partner
Are you able to connect to the Guest network, but just can't get any internet connection through it? Or are you unable to see the Guest network all together?
- rippajohnFeb 17, 2022TutorI caN Connect fine, just no internet on 2.4 or 5 ghz
What security options do you have configured?
Do you have "Allow guests to see each other and access my local network" enabled?
