Noahh
Feb 23, 2020Guide
My ping sucks
My ping when i play duos is awful I’m getting 60/70 ping in duos When my friend is the host. I try using geo filter but it doesn’t help at all(sometimes makes it worse). I am supposed to be getting 20...
Netduma-Fraser
Feb 23, 2020NetDuma Partner
What router are you using?
Noahh
Feb 23, 2020Guide
Netgear nighthawk XR450
- Netduma-FraserFeb 23, 2020NetDuma PartnerWhat game are you playing? If you're connecting directly to your friend then the Geo-Filter won't help, what happens if you host instead? How good is your friends base ping/upload speed as it may not be very good.
- NoahhFeb 23, 2020GuideI’m playing fortnite and my friend usually has good ping and all around good internet I can see what happens when I’m host because he has more points then me in competitive so he has to be host
- Netduma-FraserFeb 23, 2020NetDuma PartnerWhere are you located and where is the server you connect to when playing duos and what server are you connected to when playing solo? What is your internet speed and setup?
