Noahh
Feb 23, 2020Guide
My ping sucks
My ping when i play duos is awful I’m getting 60/70 ping in duos When my friend is the host. I try using geo filter but it doesn’t help at all(sometimes makes it worse). I am supposed to be getting 20...
Noahh
Feb 23, 2020Guide
I live in Kentucky and the closest server is in ohio. I’m supposed to get 350 mgbs but for some reason I get a lot less even though I play on wired I usually play on 30 or lower ping but my ping and download speed is slow I use a power line adapter
Netduma-Fraser
Feb 23, 2020NetDuma Partner
The power line could potentially be an issue, depending on the wiring in your home, mine wasn't very good which caused issues. I've seen it before where ping is raised when playing with others, I think its to do with the matchmaking. What ping do you get when host and have you tried directly connected to the ISP router to see what you get?
- NoahhFeb 23, 2020GuideWell when I play solos So by myself I’ve been getting pretty much the same I’ve never had this issue any other time why today though and also I don’t know if I will be able to move my monitor and pc today seeing that everyone is home and I would need to take my monitor to a different part of the house as well for the wiring part you might be right it’s not the newest house and a moca adapter won’t work because I can’t find a singing coax port in my house I don’t know why that is and also if my internet is perfect when I plug it strait in to the router what would I do because I can’t move it cause at&t has something on the wall that has cords going inside the wall so I don’t think I could move that without getting at&t involved and I’m a 13 year old kid and they will just charge me outraged charges and try to convince me that my router is good and theirs is better
- Netduma-FraserFeb 23, 2020NetDuma PartnerSo it's suddenly just occurred today? Have any changes been made to your physical setup i.e. anything added/removed or any router settings that have been changed outside the regular settings? If you do a speedtest.net test what is the ping you're getting when nothing else is using the internet?
- NoahhFeb 23, 2020GuideWell almost half of my games have been on 50 ping and ever since today it’s been every game
- Netduma-FraserFeb 25, 2020NetDuma PartnerIf you haven't changed any settings whatsoever then I'd first suggest you reboot the router just in case but then I'd recommend you use this guide to see if there is an issue with your ISP/line that may have just occurred. http://support.netduma.com/en/support/solutions/articles/16000074717-how-to-test-your-internet-ping
