traaw24's avatar
traaw24
my ping
my ping is always jumping around never really able too control it usually jumps anywhere from 48,78,119 then back to 25 every now and then my ping assist is set to 32 my settings are all setup like instructed??
  • What is your physical setup? Are you using QoS? What game are you playing? How are you measuring the ping, from the Geo-Filter or the game?
    • traaw24's avatar
      traaw24
      As instructed in netduma forum step by step .... modem to nighthawk, playstation is the only thing hardwired too the router, all devices are connected i have tried ever possible solution its the only real problem i have with the router and i have done multiple speed test from console to laptops to phone they are never accurate solutions???
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        What is the model of the modem, does it have WiFi? ALL devices are connected to the XR? What game are you playing? How are you measuring the ping, from the Geo-Filter or the game?
