Mgueddi
Sep 30, 2020Follower
My router keeps cutting internet
I have to reboot my router multiple times a day becuase it keeps dropping connection. Everything is wokring one second and then all of my devices are unable to use the internet. This is temporarily f...
Sep 30, 2020Guru - Experienced User
What firmware are you on?
What modem are you connected to?
Is it wired devices that drop, wireless, or both?
- Netduma-FraserOct 02, 2020NetDuma PartnerPlease try the XR500 3.0 beta and let us know if you get the same issues on that firmware. Would suggest doing a reset after you've upgraded to prevent any legacy issues carrying over. https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/bd-p/en-home-beta-npg-duma
