James91
Oct 21, 2020Initiate
My rx700 can not be found on nighthawk app
I lost internet last night I thought due to maintenance but I guess not. In the nighthawk app my router can not be found. I've done everything its said about 10 times. I'm not very good at tech things...
- Oct 24, 2020I ended up taking it to a friend's going on his computer with the router hooked up through his router. We logged on the routerlogin.net put in my credentials and looked through everything. Finally decided to factory reset and its as good as new. All my devices connect with internet and I'm happy I didnt throw it off a bridge.
Netduma-Fraser
Oct 21, 2020NetDuma Partner
Hold the reset button in the back of the router down for 30 seconds, then release and wait 1-2 minutes before trying to access it. Would suggest using a PC to access it, go through the Setup Wizard, it should detect internet and then you should be fine.
- James91Oct 24, 2020InitiateI ended up taking it to a friend's going on his computer with the router hooked up through his router. We logged on the routerlogin.net put in my credentials and looked through everything. Finally decided to factory reset and its as good as new. All my devices connect with internet and I'm happy I didnt throw it off a bridge.
