blackshirt40
Feb 04, 2019Guide
my wired pc doesnt show in dumo
most of the time, the dumo os doest see my wired pc, in the network monitoring section or the network map, also when are you guys going to fix the pc settings in dumo so we dont have to change our pc...
blackshirt40
Feb 06, 2019Guide
even running a speed test on my pc wont show it, and in the device manager it shows my pc off line and not connected to lan, everything works fine i guess its just a bug, ill check again but if i remember correctly not having my pc as a console wont trigger qos traffic priorataztion when i play league of legends
Netduma-Fraser
Feb 06, 2019NetDuma Partner
How do you have your PC wired to the router, is it through a switch or router before connected behind the XR500?
- blackshirt40Feb 06, 2019Guide
just cable to modem then modem to x500, im hardlined to x500
- Netduma-FraserFeb 06, 2019NetDuma PartnerWill it allow you to delete the device from the device manager? If not reboot the router, does your device show online then?
- blackshirt40Feb 07, 2019Guide
now the type changed back to pc, it was on ps4, but its still sitting in the offline section.. not showing any traffic moving or that it even has an ip address, but the internet does work just fine on pc
