Applewood1983
Feb 27, 2023Initiate
My XR1000 is only getting half of the speed it should be.
My XR1000 is only getting half of the speed it should be. I should be getting 100 mps and have been for several months. It suddenly dropped to half of that continuously. I updated the router thinking ...
Feb 27, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- Applewood1983Feb 28, 2023InitiateThanks for the reply. Just now getting to see this due to crazy work hours today. I will get this info as soon as I can and reply with it.
