Applewood1983
Feb 27, 2023Initiate
My XR1000 is only getting half of the speed it should be.
My XR1000 is only getting half of the speed it should be. I should be getting 100 mps and have been for several months. It suddenly dropped to half of that continuously. I updated the router thinking ...
Feb 27, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Applewood1983
Feb 28, 2023Initiate
Thanks for the reply. Just now getting to see this due to crazy work hours today. I will get this info as soon as I can and reply with it.
