Applewood1983
Feb 27, 2023Initiate
My XR1000 is only getting half of the speed it should be.
My XR1000 is only getting half of the speed it should be. I should be getting 100 mps and have been for several months. It suddenly dropped to half of that continuously. I updated the router thinking ...
Spandex
Mar 10, 2023Tutor
I had this problem my good man and it confused the hell out of me for ages until i looked on the device management section and clicked on the 3 bars top left and changed it from tree to table which shows the speed of the cable you are using to connect that device, the cable had gone faulty and was only registering 100mbits which should have been 1000mbits so the speed was then restricted due to that, a cable swap out solved it, hope that helps.
