geirsi
Feb 25, 2021Tutor
My XR500 completely lost - any advice?
My XR500 stopped working yesterday. I have no clue what happened or if I had automatic firmware updates on or off. I have tried all kinds of resetting, including the 30-30-30 and uploading the la...
- Feb 27, 2021Unfortunately not that I am aware of - I'd suggest opening a ticket with Netgear just in case they have some troubleshooting steps that I'm not familiar with. https://www.netgear.com/support/
Netduma-Fraser
Feb 25, 2021NetDuma Partner
I wouldn't suggest doing a 30-30-30 reset as that can damage the router. On Windows if you open command prompt while connected to the router and type ipconfig and press enter does 192.168.1.1 appear as the gateway address?
