geirsi
Feb 25, 2021Tutor
My XR500 completely lost - any advice?
My XR500 stopped working yesterday. I have no clue what happened or if I had automatic firmware updates on or off. I have tried all kinds of resetting, including the 30-30-30 and uploading the la...
- Feb 27, 2021Unfortunately not that I am aware of - I'd suggest opening a ticket with Netgear just in case they have some troubleshooting steps that I'm not familiar with. https://www.netgear.com/support/
Netduma-Fraser
Feb 25, 2021NetDuma Partner
I wouldn't suggest doing a 30-30-30 reset as that can damage the router. On Windows if you open command prompt while connected to the router and type ipconfig and press enter does 192.168.1.1 appear as the gateway address?
geirsi
Feb 25, 2021Tutor
This is what the Ethernet adapter IP config gives me ... but set this statically during the image upload trials ...
If I switch to dynamic IP the gateway is not there ...
- Netduma-FraserFeb 25, 2021NetDuma PartnerI can't see the pictures at the moment until they've been moderated but thanks for the description. When you did the TFTP method did it say that it sent/uploaded it successfully?
- geirsiFeb 26, 2021Tutor
Yes, there was a message saying 0 bytes where retransmitted and the signature, so as expected from the website guide.
Just to explain the photos:
Static config: I have subnet mask 255.255.255.0 when setting static ip (192.168.1.99) and gateway 192.168.1.1)
Auto config: There is no gateway, the mask is 255.255.0.0 and they ip (169.254.184.34)
- Netduma-LiamFeb 26, 2021NetDuma Partner
OK, if you haven't already could you now try holding the reset button for thirty seconds since doing the TFTP update?
