geirsi
Feb 25, 2021Tutor
My XR500 completely lost - any advice?
My XR500 stopped working yesterday. I have no clue what happened or if I had automatic firmware updates on or off. I have tried all kinds of resetting, including the 30-30-30 and uploading the la...
- Feb 27, 2021Unfortunately not that I am aware of - I'd suggest opening a ticket with Netgear just in case they have some troubleshooting steps that I'm not familiar with. https://www.netgear.com/support/
geirsi
Feb 25, 2021Tutor
This is what the Ethernet adapter IP config gives me ... but set this statically during the image upload trials ...
If I switch to dynamic IP the gateway is not there ...
Netduma-Fraser
Feb 25, 2021NetDuma Partner
I can't see the pictures at the moment until they've been moderated but thanks for the description. When you did the TFTP method did it say that it sent/uploaded it successfully?
- geirsiFeb 26, 2021Tutor
Yes, there was a message saying 0 bytes where retransmitted and the signature, so as expected from the website guide.
Just to explain the photos:
Static config: I have subnet mask 255.255.255.0 when setting static ip (192.168.1.99) and gateway 192.168.1.1)
Auto config: There is no gateway, the mask is 255.255.0.0 and they ip (169.254.184.34)
- Netduma-LiamFeb 26, 2021NetDuma Partner
OK, if you haven't already could you now try holding the reset button for thirty seconds since doing the TFTP update?
I tried twice more running the following procedure
1) Hold for 30 secs to get rid of the red light and get a white blinking power light, otherwise the TFTP won't send
2) Put the image through the TFTP - success
3) Hold the reset for 30 secs
Result: White blinking light on the router. No response from http://192.168.1.1 but pinging the IP gives a successful response.
Thanks for your help on this. Anything else I could try?
