NanaO
Feb 06, 2024Aspirant
My XR500 LED’s white but no internet connection
I had issues with my geo-filtering so I decided to do a factory reset on my router. Now I can’t get past through the config stage and it won’t detect an active internet connection.
Netduma-Fraser
Feb 06, 2024NetDuma Partner
Skip through the wizard, reboot the modem, wait 2 minutes then reboot the XR, wait 4 minutes and see if it gets internet then
- NanaOFeb 06, 2024AspirantAll the options I have requires an active connection, there’s nothing that can be skipped
- FURRYe38Feb 07, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.- NanaOFeb 07, 2024Aspirant
Will it be possible to roll back the firmware on this router? i'm on the latest update. I don't get why i need an active connection to set it up. I've seen a lot of reviews and they aren't good at all. Honestly i've tried everything possible known to man.
