Deadpool_NZ
Aug 10, 2020Aspirant
My XR500 Router disconnects from the Internet(intermittent)
My XR500 Router disconnects from the Internet every couple of days or weeks(intermittent) and the only way to reconnect to the internet is to power down the router. I have the largest firmware inst...
Netduma-Fraser
Aug 11, 2020NetDuma Partner
There will be a fix coming in DumaOS 3.0 but until then I would suggest in Internet Setup changing from Dynamic to Static. Also in LAN Settings set IP reservations for your devices.
- Deadpool_NZAug 11, 2020Aspirant
Hi, thank you for your reply, i will give it ago.Do you know the time frame of the update to DumaOS 3.0 will be?
Thank you and stay safe.
D
- Netduma-FraserAug 12, 2020NetDuma PartnerWell I think there is a beta build coming out this week, as to when you personally would get an invite I couldn't be sure. Could be worth tweeting the Netgear Pro Gaming twitter account, mentioning you have this issue and see if they'll send you an invite.
