jadamkeo
Jan 16, 2024Aspirant
My Xr500 wouter is only putting out 13 mbps download speed and 19 upload please help
Jan 17, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What are the speed results with a wired PC or laptop and testing with Ooklas installable speed test app?
- jadamkeoJan 17, 2024AspirantI am currently running the 2.3.2.134 version and I have the cat 6 Ethernet .
- FURRYe38Jan 17, 2024Guru - Experienced User
What are the speed results with a wired PC or laptop and testing with Ooklas installable speed test app? - Netduma-FraserJan 18, 2024NetDuma PartnerWhat are you getting on speedtest.net? How have you setup the QoS page?
