iAmazing
Mar 31, 2020Tutor
NAT Filtering is making me have less than half of my ISP Download speed
My XR300 when i put him in NAT Filtering: Open, my download that are 500mbps go to 150mbps. Anybody knows why? I need it open because i play games like Call of Duty and i need Nat: Open and not Stri...
Netduma-Fraser
Apr 01, 2020NetDuma Partner
It shouldn't affect that at all but are you not able to get an Open NAT using UPnP? An alternative would be to just put the console in the DMZ instead.
- iAmazingApr 02, 2020Tutor
Netduma-Fraser wrote:
It shouldn't affect that at all but are you not able to get an Open NAT using UPnP? An alternative would be to just put the console in the DMZ instead.I already did that. i DMZ the console and i m using UPNP, but still if i dont open the NAT PS4 says NAT type: STRICT
- Netduma-FraserApr 02, 2020NetDuma PartnerAre you reading the NAT from the game itself or the console network settings? What does it say in the console network settings? Is your XR in the DMZ of your ISP router?
