Boda
Mar 30, 2018Aspirant
NAT issue with Firmware 2.2.1.10 update?
Has anyone ran into an issue while using the latest firmware 2.2.1.10 on their XR500 router? I'm currently having a NAT problem since this update. My NAT is moderate or my Xbox One indicates that I...
Boda
Mar 31, 2018Aspirant
I have just tried everything that you have posted to do with Firmware 2.2.1.10 and still can not talk on Xbox live.
I have reverted back to trying it on both versions 2.0.0.28 and 2.1.0.4 and have no issues with connectivity.
The only issue i have with 2.1.0.4 is that Google Chrome browser will not work for logging into the XR500.
Netduma-Fraser
Apr 01, 2018NetDuma Partner
Okay so the real issue is you're unable to talk to friends and you believed that was NAT related?
You need to add your friends to your allow list otherwise your Geo-Filter will block them when you try to connect.
Also disable SIP ALG in WAN Setup.
