Boda
Mar 30, 2018Aspirant
NAT issue with Firmware 2.2.1.10 update?
Has anyone ran into an issue while using the latest firmware 2.2.1.10 on their XR500 router? I'm currently having a NAT problem since this update. My NAT is moderate or my Xbox One indicates that I...
Salty03
May 17, 2018Aspirant
I have tested with my XR500 and have been able to achieve Open NAT when setting the Xbox as a static IP and doing Port Triggering and also tested with Port Forwarding for the correct Xbox Live ports. I have also had success when setting my Xbox One S as DMZ with the static IP. If you are unable to get an Open NAT then I would contact your ISP to see what they can do on their end. I also have Comcast and haven't had any issues with this router. It has in fact improved my gaming experience by getting closer servers. I hope you can figure this out because I have enjoyed my Nighthawk XR500.
