xXKevlar79Xx
May 06, 2020Tutor
NAT TYPE MODERATE IN GAMES BO3 - PC WINDOWS 10 PRO
Hi all "Please Help - i am not the technical when it comes to PC / routers" bought myself a refurbished router xr500 connected to internet fine really easy set up, however having trouble ge...
- May 06, 2020
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
xXKevlar79Xx
May 06, 2020Tutor
just used it in router mode and then put all the port forwarding through the main smart hub - I nowhave open Nat type although slightly annoying as loose some of the featured apps - so think still need to for alternative work round to resolve issue although this will do for the moment
massive thank you :)
did look at this earlier but did not go through with the changes - oh well zombies to see how it plays
May 06, 2020Guru - Experienced User
Enjoy. :smileywink:
