pinkfloyd
Mar 08, 2019Tutor
Need Advice If I should get these routers????
So I am torn on trying the XR500 again, I tried it a few months ago and man to many issues. And from what I see on this forums the issues are still there. Now I see the XR700, seems like a soild rout...
Netduma-Fraser
Mar 09, 2019NetDuma Partner
What issues were you having and I can let you know if they are still something to be concerned about. The XR700 is a fantastic router in my opinion, especially if WiFi is really important to you. I don't believe the XR700 has the XR500 issues you're probably referring to. It'll be able to handle your connection no problem.
