SirPenguin
Mar 23, 2018Follower
Need Advice
Hello, I live in an area of London that has terrible wifi at least speeds of 1mb/ps for download (if lucky), and at least 0.50mb/ps for upload. Will a nighthawk router or any other router improve my ...
Netduma-Fraser
Mar 23, 2018NetDuma Partner
Hi SirPenguin, no router can improve your speeds, the speed you get is down to your ISP. The only reason a new router would improve the situation is if your current one was somehow configured incorrectly or was faulty which is the reason you get those speeds.
What speeds do you pay for from BT?
It would be compatible with your home network yes.
