Pbino88
Apr 15, 2022Follower
Need help before buying xr1000
I’m trying to find out if the xr1000 nighthawk router supports NAT loopback. I’ve been eyeing the 700 but there’s none in stock anywhere. Anyone knows info on the xr1000 support loopback? I would greatly appreciate it. Can’t really find a source anywhere. Also this article https://kb.netgear.com/000049578/Which-NETGEAR-routers-support-NAT-loopback is out of date. Doesn’t have info on the xr1000
1 Reply
- Netduma-FraserNetDuma PartnerThe XR700 is no longer being made/sold unfortunately.
If the XR300 has this capability then the XR1000 almost certainly does as it is the most up to date router currently. I've not seen anyone use any of the XR routers for this purpose so I couldn't say for sure. You could always purchase, test and return if it doesn't work.
