MRS911
Mar 26, 2020Guide
need help for netgear xr500
Hello I have been using Router Netgear XR500 for a long time, but I don`t know what the correct settings should be used in order to enjoy playing online. Sometimes I encounter a delay in response ...
- Apr 01, 2020Does the console report an Open NAT? If so then the game will have an open NAT also, it will most likely be the Geo-Filter causing a misreading. You could use either option but I wouldn't suggest using both, probably DMZ would be more secure/considerate of your other devices.
Netduma-Fraser
Mar 26, 2020NetDuma Partner
I would recommend you go through our optimal settings guides here: http://support.netduma.com/en/support/solutions/folders/16000090646 then if you have any issues/questions we can go from there. Please note that due to the global issue going on at the moment that services are under heavier load than usual and so can result in higher than normal pings/lag.
MRS911
Mar 26, 2020Guide
my problem before 3 months ago , just i want know about my settings is good or not ?
- Netduma-FraserMar 26, 2020NetDuma PartnerYour settings look okay but you've not shown everything that could affect the connection so I couldn't say for certain. By looking at the guides you can fine tune those as well as get a better understanding of how the router works.
- MRS911Mar 26, 2020Guide
I can show you exactly what settings you need. Just tell me and I'll put it here.
I feel something wrong with my settings.- Netduma-FraserMar 26, 2020NetDuma PartnerIt would be much easier to go through our optimal settings guides as it is all detailed there. What is the average ping you're getting to the game?
