MRS911
Mar 26, 2020Guide
need help for netgear xr500
Hello I have been using Router Netgear XR500 for a long time, but I don`t know what the correct settings should be used in order to enjoy playing online. Sometimes I encounter a delay in response ...
- Apr 01, 2020Does the console report an Open NAT? If so then the game will have an open NAT also, it will most likely be the Geo-Filter causing a misreading. You could use either option but I wouldn't suggest using both, probably DMZ would be more secure/considerate of your other devices.
MRS911
Mar 26, 2020Guide
my problem before 3 months ago , just i want know about my settings is good or not ?
Netduma-Fraser
Mar 26, 2020NetDuma Partner
Your settings look okay but you've not shown everything that could affect the connection so I couldn't say for certain. By looking at the guides you can fine tune those as well as get a better understanding of how the router works.
