MRS911
Mar 26, 2020Guide
need help for netgear xr500
Hello I have been using Router Netgear XR500 for a long time, but I don`t know what the correct settings should be used in order to enjoy playing online. Sometimes I encounter a delay in response ...
- Apr 01, 2020Does the console report an Open NAT? If so then the game will have an open NAT also, it will most likely be the Geo-Filter causing a misreading. You could use either option but I wouldn't suggest using both, probably DMZ would be more secure/considerate of your other devices.
Netduma-Fraser
Apr 01, 2020NetDuma Partner
MRS911
Apr 01, 2020Guide
in ps4 console i have NAT : 2
so now better for me using DMZ with UPNP enabled ?
UPNP just only open one port : 3659 UDP its normal ?
- Netduma-FraserApr 01, 2020NetDuma PartnerNAT Type 2 is open, that means it is behind a router so that is good. Yes you could use DMZ with UPnP. It is normal as it will only show ports that are open at the time/when they are needed.
- MRS911Apr 01, 2020Guide
thank you so much for ur help :) Netduma-Fraser
