fatpigpigboy
May 16, 2020Aspirant
Need Help for XR700 no 2.4/5G wifi after suddenly shutdown
Hello to all forum members. I really need a help now. My XR700 suddenly shutdown and i just re-power it . After that , there were several issues: 1. There is no 2.4G / 5G wifi after re power...
Netduma-Fraser
May 16, 2020NetDuma Partner
Do a factory reset by holding the button down in the back of the router for 30 seconds, then let go, wait a minute then connect to the interface and do the setup wizard. Does it work properly after that?
- fatpigpigboyMay 16, 2020Aspirant
tried , same issues. Only can use with wired port . Wifi still no functions. DumaOS still no access.
Thanks.
- Netduma-FraserMay 16, 2020NetDuma PartnerHow are you trying to access the interface? Can you access using routerlogin.net or the LAN IP? If neither does it work if you access using routerlogin.net/adv_index.htm ? If so factory reset from there instead.
- fatpigpigboyMay 16, 2020AspirantGoing through routerlogin.net or lan ip will go into Dumaos not loaded yet issues.
What I can control my router are through routerlogin.net/adv_index.htm
I tries hard reset, upgrade or downgrade firmwares, enable, disabled 2.4 /5 G wifi still no luck.
Now I believe it was the wifi module are dead after suddenly shutdown.
Thanks.
