xReddys
Dec 15, 2023Initiate
Need help on suspicious logs [LAN access from remote]
I been looking at my router logs recently and been seeing a lot of [Lan access from remote] logs that I can show. I've done my search on this topic and seem it could be someone trying to access my ne...
Netduma-Fraser
Dec 15, 2023NetDuma Partner
NG routers can be quite sensitive when it comes to the logs, a lot of times its just connections you've come in contact with. One of the IPs is Google for example. As long as you have Remote Management disabled in settings (it is by default) no one can access your router
