ikassi
Nov 17, 2024Aspirant
Need help optimizing speed
I have a netgear cm1000 modem and a netgear xr1000. I picked up 1200 gbps from xfinity and the router is only getting 460mbps download and 24 upload The modem is hardwired and the modem is hardwire...
Netduma-Fraser
Nov 17, 2024NetDuma Partner
Are you testing the speed using the in built speedtest? If so, ignore that, set the speeds you expect (1000 down / 24 up) and then do a speedtest.net test via ethernet, do you get better results then?
- plemansNov 18, 2024Guru - Experienced User
hardwire the pc/laptop directly into the cm1000 and test the speeds. Pointless to troubleshoot a router before finding out if you're getting full speeds.
