StellaJonas
Aug 31, 2023Follower
Need Help Setting Up Port Forwarding on Nighthawk Pro Gaming Route
recently got myself a Nighthawk Pro Gaming Router and I'm having a bit of trouble setting up port forwarding. I've been trying to follow the instructions in the manual, but it seems like I'm missing ...
Netduma-Fraser
Sep 01, 2023NetDuma Partner
What is the issue you're having with setting it up exactly? As long as you have an Open NAT, port forwarding won't do anything further for your connection quality
