Xboxlivegamer
Mar 03, 2018Aspirant
Need help with XR500 double NAT on Xbox One
Hello, I installed my XR500 today, before I was using an AC1900 which had open NAT, however I now have double NAT at Strict. What questions should I ask my internet service provider and what settings...
- Mar 05, 2018
I found the solution to my double NAT Strict NAT problem, I had to call my ISP and they accessed my modem to changed the MAC address of my old router to my new router's MAC address, this solved my problem and my NAT is now Open on Xbox live.
The reason I could not do this myself is because I'm not allowed access to my router which is located on the roof of my house. The modem I use is a green packet.
Thank you to Netduma-Fraser for leading me in the right direction towards the solution.
Netduma-Fraser
Mar 03, 2018NetDuma Partner
Hi there - the best thing to do would be set your modem / router to 'modem mode' or 'bridge mode'. This disables the router functionality on the modem, which will fix the double NAT problem.
Please also do this:
1. Make sure UPNP is enabled (go to >Settings >Advanced Settings >UPNP)
2. Go to Port Forwarding ( >Settings >Advanced Settings >UPNP) and delete any manual port forwarding rules you added.
You should then be good to go!
- XboxlivegamerMar 03, 2018Aspirant
Does that mean I have to called my ISP and ask them to set it to modem or bridge mode? There's no way on my end to manually configure it.
The two other suggestions are default settings already.
- Netduma-FraserMar 03, 2018NetDuma PartnerNo, your ISP will not be able to do this.
Usually you can connect to your modem quite easily. I can help you do this.
On the XR500 UI, please go to System Information. On the Internet Status Panel (bottom left), what does it say your WAN IP is?- XboxlivegamerMar 03, 2018Aspirant
192.168.0.100
