Angrybee
Aug 14, 2018Tutor
Need Some Help Please..
i'm not sure what is going on. i had restarted my Modem and Router, just to be on the safe side anyhow i have seem my router log saying that i am being DDos. and it looks like my router crashed or s...
Aug 14, 2018Guru - Experienced User
Disconnect the WAN port from the modem then reboot the router. Look at the logs again. Still seeing this?
What is the Mfr and model# of the ISP modem?
- Netduma-FraserAug 14, 2018NetDuma PartnerIt's not a DDoS attack. Its a common entry on Netgear routers. The log is verbose as it's primarily for development teams so I would not pay attention to it. Are you having an issue?
- AngrybeeAug 14, 2018Tutor
i'll be sure to try that and i am running a comcast modem there new one ARRIS Group, Inc. TG3482G and sometimes the net is like is slowing down. not sure if it due to not having qos set right or what.
- Netduma-FraserAug 14, 2018NetDuma PartnerWhat are your QoS settings and what are the paids you pay for?
250 down and 12. upload
- FURRYe38Aug 14, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the XR router gets from the modem.
- Netduma-FraserAug 15, 2018NetDuma PartnerWhat do you mean exactly by it's slowing down? From your current settings speeds will be throttled when it detects gaming. Is that what you mean? It's to prevent local congestion but you shouldn't see a noticeable impact online only on a speed test. Also make sure that bandwidth allocation share excess is enabled for both download/upload. You should only have DumaOS Classified Games enabled in Traffic Prioritization or a manual service for a game. If you've done ports and it's too broad that will be the issue.
