Angrybee
Aug 14, 2018Tutor
Need Some Help Please..
i'm not sure what is going on. i had restarted my Modem and Router, just to be on the safe side anyhow i have seem my router log saying that i am being DDos. and it looks like my router crashed or s...
Aug 14, 2018Guru - Experienced User
Disconnect the WAN port from the modem then reboot the router. Look at the logs again. Still seeing this?
What is the Mfr and model# of the ISP modem?
Netduma-Fraser
Aug 14, 2018NetDuma Partner
It's not a DDoS attack. Its a common entry on Netgear routers. The log is verbose as it's primarily for development teams so I would not pay attention to it. Are you having an issue?
