PapaLung
Aug 04, 2022Apprentice
Net duma geo filter
About a week ago I noticed the server location for Microsofts dedicated ipv6 server for the western US is showing in Great Britain. I've also noticed that the ping heat map is not showing all of the w...
- Aug 05, 2022
You should ideally have the filter enabled before you boot the game. This is because the game client searches for servers on boot, if you have filtering mode disabled it will then think that all known servers are available to it when they won't be after enabling filtering mode.
Netduma-Fraser
Aug 04, 2022NetDuma Partner
The authentication servers like that don't really matter where they're located as you will connect to them regardless but in response to both, resync the cloud on the Geo-Filter and the Ping Heatmap pages, click the ≡ icon on each panel to do so.
