PapaLung
Aug 04, 2022Apprentice
Net duma geo filter
About a week ago I noticed the server location for Microsofts dedicated ipv6 server for the western US is showing in Great Britain. I've also noticed that the ping heat map is not showing all of the w...
- Aug 05, 2022
You should ideally have the filter enabled before you boot the game. This is because the game client searches for servers on boot, if you have filtering mode disabled it will then think that all known servers are available to it when they won't be after enabling filtering mode.
PapaLung
Yeah, I'll select an area , turn on the filter and search for a game and it tries to connect me to servers outside of the selected area. Before I even choose an area I want to play in I make sure to close out the game, delete the games saved data, then I select an area i want to try to connect to on the map, I then start the game, load into the lobby screen, turn on the filter and search for a match. I've also done this process with the filter on and area selected while stating the game instead of waiting until it loads to the lobby screen. It makes no difference. Once I turn off the filter, it will connect to the game servers on its own, sometimes to the exact server I was trying to isolate in the beginning but not always.
Netduma-Fraser
Aug 04, 2022NetDuma Partner
Try this:
Quit the application/game/client completely
Remove device from the Geo-Filter
Give PC PlayStation Device Type in the Device Manager (if on PC)
Resync from the Geo-Filter Map menu
Re-add the device to the Geo-Filter with the manual option
Set up the Geo-Filter how you like
Wait 2 minutes
Boot up application/game/client
Then see if it works.
Wait 2 minutes
- PapaLungAug 04, 2022ApprenticeI gave that a shot, it's still doing the same thing.
- Netduma-FraserAug 04, 2022NetDuma PartnerWhat game are you trying to filter exactly? Can you provide a screenshot of the Geo-Filter page showing it happening please?
- PapaLungAug 04, 2022ApprenticeIm playing warzone on xbox series x. What it looks like with filtering mode on searching for a game. It doesn't even attempt to connect to the area selected. It tries to connect to CA servers, or TX servers ect. never to the area I've chosen. I'll send a picture in another response showing all the servers that pop up for warzone when I back out, turn off filtering and reload into the game.
