PapaLung
Aug 04, 2022Apprentice
Net duma geo filter
About a week ago I noticed the server location for Microsofts dedicated ipv6 server for the western US is showing in Great Britain. I've also noticed that the ping heat map is not showing all of the w...
- Aug 05, 2022
You should ideally have the filter enabled before you boot the game. This is because the game client searches for servers on boot, if you have filtering mode disabled it will then think that all known servers are available to it when they won't be after enabling filtering mode.
Netduma-Fraser
Aug 04, 2022NetDuma Partner
Did you completely quit the game so you were back on the Xbox dashboard? I suspect you're not able to get a game because your area is so far away from your actual location that you're hitting a ping limit and it's preventing you getting a game
PapaLung
Another thing I forgot to mention is that I am constantly having to log into the router when I'm using the geofilter and or using any other rap that the router has to offer. I'm not sure if this is important information or not.
