PapaLung
Aug 04, 2022Apprentice
Net duma geo filter
About a week ago I noticed the server location for Microsofts dedicated ipv6 server for the western US is showing in Great Britain. I've also noticed that the ping heat map is not showing all of the w...
- Aug 05, 2022
You should ideally have the filter enabled before you boot the game. This is because the game client searches for servers on boot, if you have filtering mode disabled it will then think that all known servers are available to it when they won't be after enabling filtering mode.
Netduma-Liam
Aug 05, 2022NetDuma Partner
PapaLung
Aug 05, 2022Apprentice
I factory reset AGAIN, reinstalled firmware, set everything up, chose geo location to play in via polygon mode , turned on geo filter, turned on xbox, erased warzone saved data from console, started warzone, searched for a match and it worked this time. I've done it where I turn on geofilter after I log into WZ but before I search for a game, but, I'm not going to anymore, my blood pressure can't take it. Thank you for your patience and help!!!
