Wyzfar
Aug 08, 2021Aspirant
Netduma r2
Does anyone know if the netduma R2 has the same issue in device manager where the software does not recognize the device being on when it is. with the nighthawk XR Series specifically still in the cu...
Netduma-Fraser
Aug 09, 2021NetDuma Partner
You should upgrade to the .120 beta version for the XR which has made this better, as far as I'm aware the R2 doesn't have that issue
