JoeFI's avatar
JoeFI
Apprentice
Mar 04, 2021
Netduma v 3.0
Hi,
Can anyone download the netduma v3 OS now? I am looking to install it on my xr500 if possible.
Regards
Joe
  • michaelkenward's avatar
    michaelkenward
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
    Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
    Nighthawk Pro Gaming Routers - NETGEAR Communities
    This is especially important for these devices as they run with DumaOS rather than the standard Netgear firmware. The DumaOS people are very active in that section and can probably respond more quickly.
    I will ask the Netgear moderator to move your message.
  • I see you've found the beta forum! Post in that thread if you experience any issues or have any further queries.
